Help identify turbo and its potential
Sy-1177
Turbo Inside
Basically, I have 2 turbos and plan to use one of them, but i'm trying to figure out which one to keep. I have this 20g (which I posted in the fol sale section) which I know would be a good upgrade but may or may not require a higher stall, idk? Then I have this one which is a hybrid but I dont know much about it. It has a stock exaust side (8cfm) but a bigger compressor housing. I think it may be a 60-1 but not 100% sure. I'm assuming a bigger compressor wheel and the compressor housing has been installed onto a stock exaust side, is that all that is needed to make this thing? Can anyone give any input on what I may have here and which would be a better fit for a basically stock truck?
Darin
Re: Help identify turbo and its potential
Can you take more pics of the exhaust side? Are you sure it's an 8cm housing?
That's a real mismatch if it's a 60-1 on a stock turbine side. Can you take off the compressor housing and carefully measure the compressor wheel?
Sy-1177
Turbo Inside
I can take some of the exaust side later today. It does have an 8 stamped on the exaust input and accepts a stock downpipe so thats why I assumed its a stock exaust side. I'll try and measure the wheel too. :tup: Thats just it, I dont want to try and run this thing if its not setup properly... or maybe I can just buy a bigger exaust housing for it? But then if I did that, would I need a different wheel?
Darin
What are your goals? Within reason, of course. Everyone wants to run a 9 flat :)
The 20G may be a better choice, with a 10cm housing on it.
Darin
It's a garrett compressor housing, the T on it is Turbonetics. Looks like a T04S cover, actually.
I'm really intrigued on how they mounted it all together.
Take the pics. They may have machined a garret center section to fit the mitsubishi turbine housing. If that's the case then swapping a larger turbine wheel is much more difficult.
Think about your realistic goals, and post them up!
Sy-1177
Turbo Inside
I'll take some pics and measurements this evening for sure. Im not looking for an all out race truck or anything, just a little more pep in my step! :lol: I want my truck to remain relatively stock, just supporting upgrades like fuel pump, chip, 3 bar... ect. My last Sy had a 20g and I ran a 12.50 with that one.... If I could do the same with this one i'd be happy.
Darin
Keep the 20G.
Good thing about the 20G is you can upgrade both the turbine wheel and compressor wheel, all using the same housings. That's if you're wanting a little more than a 20G.
If you want to keep it stock looking the 20g will fill that need. Proper tune won't need a higher stall to work well.
The other one depending on how well it was done may be good for more power, although the 8mm housing seems small for that effort and odd.
20g in my eyes is a very small upgrade from stock and almost not noticable from seat of the pants, at least in my experiences.
That photo looks identical to what I have and it's a 60-1. I have the big turbine housing and wheel. Works extremely well as far as I can tell. Meaning I've never driven any other truck than mine. It will require a modified setup to get from the turbo to the IC.
I, to, would like to see the rest of this thing. Particularly the wast gate actuator.
Sy-1177
Turbo Inside
Don, i've looked at a few of your posts regarding your turbo when I first got this thing. It made me think its very similiar to what you have. (now you confirmed it) Do you have the stock 8cm exaust side on yours?
atkonkler
Is this your bush?
I run a 20g that had a 10cfm exhaust housing....but I port matched it to more likely a 12cfm and it runs fine...I do though have a 2400-2600 stall converter with my trans rebuild. It runs and build boost just fine....with the 20g and port matched housing.
I have the 14cm housing with the the wheel that has one less blade. I think the stock housing is very restrictive. Based only on my experience with my setup you might have trouble keeping boost down around 14.
Sy-1177
Turbo Inside
Yeah, im pretty sure my old Sy had the 14cfm 20g on it and it wouldnt build boost for shit.... I threw in a 2800 stall and BAM! Night and day difference!
Ok, thats good to know. Yeah, this 8 cfm exhaust side may be the weak point on this thing. I'll get all the measurements later tonight on this thing and post them up.
Thanks for your input thus far guys! :tup:
Sy-1177
Turbo Inside
Ok, so here are some more pics. The exhaust inlet is stamped 8 just like my stock turbo, but the wheel on the exhaust side looks slightly different. I couldn't measure that because I couldn't get the center section free from the exhaust housing but the downpipe hole is the same measurement as my stock turbo. The compressor wheel measures 75mm round. Not sure what that equates to. It appears the wheel has already made a little bit of contact with the housing too. Let me know what else you would like to see.
Here's my setup. However, notice how the inlet is shortened on your turbo? I know you have nothing to compare it to but it HAS been shortened. Reason, at least in my case, you can't get a cobra elbow on it otherwise. See below.
In addition I'm about 90% sure the AC mount will still fit. I kinda stuck mine down in there and it looks like it will still fit.
Sy-1177
Turbo Inside
Cool thanks for the pics. So what are the negatives by having this small of an exhaust side?
Darin
Your turbine wheel is clipped. That'll help a bit.
Note that Don has an 11 bladed TD06H turbine wheel, which is much larger than the stock TD06. I personally feel that still, the 20G is a better alternative based on the fact that the 60-1 has the stock hotside, although clipped.
My suggestion: keep the 20G. Buy a 10cm housing for it for $200 if you don't plan on using a converter at all. The Mitsu turbos are easily upgraded. Or, sell them both and buy a new turbo that's exactly what you want.
Darin
From what I can figure out, 75mm is a 60 trim, and 76.2mm is a 60-1.
