Help in Pa needed for tuning modded syclone
turbo"O"
I'd like to simply use the ultimate 50lb chip, but I've got an ATR cam, 195/200 duration
with .430" lift. The ultimate was programmed for the 412 cam, 205/210 duration with ~.500" lift. You guys think the ultimate could work? Other engine mods include
forged pistons .30over stock compression
50lb inj
1000mm tb
800cfm turbo
ported heads/intake
headers & 3 inch exhaust no cat
upgraded fuel pump/ adj fpr
aux intercooler
Dave O
100in6
100in6
Re: Help in Pa needed for tuning modded syclone
you might be better off instead of the ultimate to hook up with someone who has a pocket romulator and datamaster and tune for your own build. phil long and mark shaffer on this board are both good tuners with it and also good guys with helping folks. maybe mike renz can give you a hand. he's around penn state.
cloneman315
sounds like with that combo u better give phill or someone a call ,i think u need a custom burn, to many diff things going on there
turbo"O"
OK. I'm going to get datamaster readings soon. Then whats the next step?
thanks
