Help: Interior beeper won't go off
Ty0279
Historically Significant
Started up the Ty this afternoon and normally the interior beeper-alarm/buzzer goes off for a few seconds, like it's supposed to. (Also when the key is turned or door is open, key is in, lights on, etc..)
But today the beeper continued to beep even while the truck ran/drove. I shut it down, checked all doors, lights, and it was still going off driving me nuts.
Disconnected the battery, ....reconnected it, ......still buzzing.
How do I get this thing to shut off? I looked under the dash for something to disconnect, but didn't see anything.
Need some help here before I have to drive w/ earplugs in. :( :lol:
TIA
Captain Morgan
Moderated User
mine did that once as well, all I did was put the key in the ignition and go to the off and on and off and on positions a few times. Make sure you do this with the door closed though, cause it does it normally with the door open, so you wont really know when it stops.
Ty0279
NJTy180 said:
mine did that once as well, all I did was put the key in the ignition and go to the off and on and off and on positions a few times. .
Gave that a try, no good. :(
I took off some of the interior pieces under the steering column and found the culprit.
Maybe these things go bad after awhile. All wires underneath looked ok. Everything is quiet now when I turn the key...just hear the fuel pump and IC pump. 8)
