OK so I'd like to make a minor adjustment to my Ultimate to reflect the rather poor quality fuel available in Cali. I'm also doing this to start down the path of tweaking my own chips, gotta start somewhere.
All I want to do is to take a little bit of timing out of the higher boost levels, I'd rather do this than just spin the distributor back a few degrees (which messes with the idle timing, etc.)
I'm a bit confused about how the Ultimate interfaces with the stock piggybacked chip. Does the Ultimate look at the stock chip and then make adjustments to that parameter (Add one degree of timing here, pull one out there, etc.) or does it have 16 complete sets of data that can be individually tweaked? In the first case, I could just go in and tweak the stock ROM slightly using Programmer 01, and my adjustment would be "updated" across all of the programs right?
If it's the case where there are a whole slew of programs that can be individually adjusted, how do I load those into programmer 01?
Someone help me out here, some basic info would be great. I.e. "the stock chip isn't what you need to play with, what you need to do is to open up the ultimate box, pull this other chip and load it via...." That type of thing.
Thanks!
Thanks!
