Help me with my checklist...
Makaveli
Still preppin' for the rebuild... here's what I've got so far... any input appreciated! :lol:
TRW pistons
Total Seal Rings
L35 rods
Freeze Plugs
ARP 2 bolt main stud kit
High pressure oil pump (need high volume)
New motor mounts & bushings
Racetronix fuel pump kit
Vac fitting
L35 heads
K&N breather
Conrad cap & rotor
CR42TS plugs
(everything new except for rebuilt heads)
I know I need....
Rod & Cam bearings
New Vac Lines
Gaskets
What else?? I was just brainstorming a bit and figured I'd post this up... :p
myclone
Timing chain?
ARP or similar companies oil pump drive shaft (you need that)?
Head bolts?
front seal for trans (might as well replace it while the eng is out)?
Sy-1177
Turbo Inside
T-72 Turbo
External Wastegate
Stall converter
Air-to-air intercooler
50lbs injectors and chip
hahahaha, just playin man!! Well, not really but it looks like your almost all set there! :drinking: :D
myclone
Push rods? (prolly reuse your old ones if your staying with the stock cam)
Tack weld pick up to oil pump. (remove the bypass spring first)
Trim the tabs off the timing cover so it can be removed later without dropping the oil pan for a cam change?
Shim the oil bypass in the block where the oil cooler adaptor bolts on? (I think Im the only one that does this :D )
ed hess
race or get outta the way
myclone.
what does shiming this do?
Of course i didnt do it, but what would it do and how do you actually shim it.
I did replace mine during the build.
ed
myclone
ed hess said:
myclone.
ed
Same thing as having a higher pressure spring in the oil pump bypass. It forces more oil through the filter and less of it get bypassed back to the pan. If you use a high output pump this little bypass just opens up further somewhat negating that high zoot oil pump. I take it out and put a ~1/16" washer under it then reinstall it. It also bumps the oil pressure up a bit.
canadian
sy in progress
anybody have any opinions on cleaning up/radiusing the oil drain back holes in the block and the one in the oil pump?
myclone
Did someone say they wanted an opinion?? WHOO HOO..
Seriously, I clean all the casting flash out of a block including the oil return holes. On the oil pump I radius where the port opens up into the cavity where it bolts on the main cap. I do the same with the main cap.
My theory is every time the oil gets sheared it adds heat and possibly adds air in minute amounts. Add enough of those shears up and youve got airiated(sp?) oil or at the least oil thats not consistant in its capability. The pressurized side of the 4.3s oiling system is kinda marginal anyway so anything I can do to help it is good IMO. My theory might be flawed but then again I dont wanna waste a crank/rods/bearings testing it.
nightdiver
Id say go with srps.They are lighter with more silicon for tighter clearances
and yes ...you need a cam also
Sy769
ed hess said:
myclone.
ed
I believe mine has a plug where the bypass spring used to be. Shouldn't be a problem unless the oil filter gets plugged in which case I have bigger probs anyway.
