Help moniter intake temps, what do you think.
ABOSS
I was thinking of using something like this to monitor temps of the air going into and out of the IC. Link to moniter
I would put the probes in the inlet and outlet of the IC and make a housing for the gauges in the ashtray next to my switches. So if temps arte getting hot I can turn on the IC fan.
Not bad for $15.00
sytyguy
Moderated User
Re: Help moniter intake temps, what do you think.
One thing to keep in mind is that often times, PC temp monitors have a pretty slow refresh rate. I used a pair of LCDs (the kind that are flush mounted in a lot of cases now) back in the day ('98-'99) and they were pretty anemic, refreshing every 3 seconds or so. Helpful for steady cruising, but too slow for fast changes.
Just check the refresh rate of the unit and as long as it's @ least 1 fps, they should work well (would obviously be better with a 2-3+ fps rate.) But, I agree with Renz, run the fans as often as possible regardless of temps.
Hood
