OK, here's my list of what I used and had no problems. You should get yourself a can of PB blaster or WD-40. You will come across a bunch of rusty bolts, a few of mine broke so I wanted to replace everything. I will post a few pics in the next post if I can find them.
The rivets I used are these. RV-120 They are used on the door pieces, rocker pieces, bumpers and the rear bumper corner pieces, and the pieces in front of the rear wheels. http://www.thefastenerwarehouse.com...0333/216390.htm
The 7mm head screws I used ... These are used on the front fender claddings, rear eyebrow pieces, the ieces in front of the rear tires and the rear buymper corner pieces. http://www.thefastenerwarehouse.com...8827/215057.htm
I dont have my front bumper back yet and I dont remember what rivets to use for the front bumper cover. I know you can use the ones I stated above for most of it but I think on top where the cover mounts on the front bumper support there are plastic ones used, I am sure someone on here knows what ones to use. Here's a few other misc stuff I bought but dont know if I am gonna use it.
No problem, yes the rivet that DaveP showed you is correct too. Also I was missing a few of the fasteners that hold the rocker pieces on. I was told by a board member to use these. NAPA 665-3320 Thats the NAPA part#. They worked very well if you loose some or they are missing.
