Help needed with gas leak!
myML320on22s
Mods please move this to the correct section as I was unsure exactly where to out this. Just went to start my TY to take it to work , first time out after being stored for the winter other then a few weeks ago to fill her up with some fresh premium gas. I start her up and head down the drive to get my mail while she warms up and idles in the garage and as I am walking back up the drive I notice from the rear something leaking, not a few drops like noticeable leak. Appeared to be running down of the gas tank, only had a minute as I was on my way to work but it smelled like gas and looked to be running off the front and rear top of gas tank. I immediately shut it off apon noticing and then quick gave a look before having to leaving in my other vehicle. Any ideas or suggestions of where to start looking or problem solving? I hope to tackle this in the next few weeks when time permits.
Thanks in advance
Nate
Peter
my Ty and me 25+ years
Re: Help needed with gas leak!
Probably one of the fuel lines on top of the gas tank are leaking. As I recall, there four lines. Fuel supply and return, and a couple vent lines. Since it only leaks when running, it will be the supply or return line. You have to drop the fuel tank and see what is going on. Maybe you get lucky and it is a loose fitting, but not likely. Good luck.
myML320on22s
Are the fuel lines hard lines? I was assuming they were rubber lines and hoping if anything it would be just a matter of replacing a section or just one whole line. No the truck doesn't leak gas when not turned on. I was afraid of having to to drop the tank to see and get to everything especially after having just filled it up! Anyone have any I for or suggestions or links on dropping the tank?
Nate
blue83z
Nate, off the top of my head, most of the lines in the fuel filter area had been replaced with rubber. I believe was still metal out of the tank. I never had the tank down.
There was a fuel leak when I has it, had a loose clamp. I replaced the filter and tightened up the clamp and was good to go.
myML320on22s
Matt from just briefly looking at hit before having to leave I wasn't really able to see much or anything that looked like a lose clamp or hose, just seemed like most of the hoses and clamps seem up top of the tank. Your saying that you were able to replace the lines and clamps without dropping the tank?
blue83z
I didn't replace any lines that I recall, but there was a loose clamp. The fuel filter is maybe 2' from the tank though, may not even be related.
myML320on22s
Yeah I hear ya Matt ...just trying to get some ideas before tackling this. Not really wanting to drop the tank, anyone dropped the tank and have any advise or how to tips?
pearl91chevy
i dropped my tank recently to throw a aeromotive pump in, had 3/4 of a tank and did it myself.. i used a jack with a peice of wood to help hold it up.. the only real issue i had was trying to lift it back up, the fuel started sloshing and made it unbalanced. overall took maybe hour and half once i got the bolts broken loose for the gas tank straps
myML320on22s
Once the bolts are lose are you able drop the tank down to the ground or is there a bunch more involved in disconnecting and unfolding etc? Hoping I just csn drop the tank and just need to replace maybe a clamp or piece of hose for the line
pearl91chevy
There is a plastic shield you have to get off first, then there is 4 gas tank stap bolts. Once you start getting those off you will notice the tank will want to fall, make sure you get something underneith to hold it up from doing that. You might be able to tilt it from Underneith to get to the problem once you have it unbolted but it will be tight fit and will put strain on the fuel lines up top
