Ty0279 said:I know my oil pressure needle will whip around under the pin one of these days.Sometimes on start up, it'll whip up to the 12 'o-clock position and then bounce back.
ed hess said:you are ok
if you didnt have oil pressure the op switch is tegrated with the fuel pump and will shut the fuel pump off. Ied
ed
if you didnt have oil pressure the op switch is tegrated with the fuel pump and will shut the fuel pump off. I think if you look closely at the gauge you will see the needle has sup around the top of its travel and is now resting on the backside of the pinstop. Take the dash apart and move the needle countercloskwise around to the other side and you will be good to go. Mne did it to, as well as mad mike on the board here
ed
