HELP ON BOOST
syclonekid43
my sy gets about 13 psi in first and second gear as soon as i hit third i only get 10 psi of boost im really starting to get sick of this truck it seems like one thing after another i was thinking if the timing was off but it was set at zero. i remember seeing a post on how the harmonice balancer can screw things up for timing something about it not lining up with tdc of number one piston anybody seen this post or ever have this happen to their truck or anybody have any ideas what this could be :bad-word: :microwav:
SY756
Have you checked out your CAT? The way you are describing, it could be a plugged up cat. Yes, the Balancer can be off, but unless your harmonic balancer has gotten way off, by like over 5 degrees, you shouldn't be seeing that kind of problem, although it may be worth looking into. One of the guys here in our group made up a pressure gauge that screws into the bung of the O2 sensor so when you start up the truck you can watch what kinda back-pressure you are getting. Pretty handy tool.
Maxtor
In addition to the CAT - check your WG adjustment. If you have a factory setup, you should have 7/8 overlap with the eye of the rod and the WG lever.
Also, if you have a scan tool or aftermarket boost guage, run a "base boost" check - hook up a vacuum line directly from the compresser to the actuator (bypass the solenoid). You should get a pretty solid 8-10psi.
syclonekid43
it got a new aftermarket cat on it its about 3 months old how would i go about to bypass the solenoid and hook up a gauge to it ill have to check that out monday and also i want to put a set of plugs while im at it but i dont know if i should go with ac delco or with a set of ngk plugs
anryo
Re: HELP ON BOOST
Can someone please expalin, I don't get it, what does mean 7/8 overlap? Is it in inches, measured from the center of the rod to the center of the hole in the arm? Seems kind a lot to have the arm almost an 1" extended. Or is it normal? :oops:
Damian
Re: HELP ON BOOST
It's not inches. The best way to adjust the wastegate actuator is to adjust it so it slips onto the lver easily, then screw it the actuator in 2 more turns.
Couger1968
Dazed and Confused
Re: HELP ON BOOST
The rod should need to be pulled slightly to go on the pin. 7/8 of the hole is about 1/16" to make it go on. I run a Forge now and it allows you to skip everything and hook up like from turbo port right to the actuator. You can then adjust boost by turning the rod in and out.
anryo
Re: HELP ON BOOST
So it is 7/8 from the DIAMETER of the hole on the rod? In normal condition, the hole of the rod is nearly "beside" the pin of the arm?
Like in below picture, but instead of 1/2 hole, it has to be 7/8?
anryo
Re: HELP ON BOOST
Thank you - now I got it, that the preload has to be very little. Almost non excistent.
(And my preload of ~1/4" is waaay too much)
Damian
Re: HELP ON BOOST
That's how you set it up.
