help on Injector size?
warmpancakes
HERES THE IMPORTANT PART OF THE SET UP, pTE 52 KIT, PORTED L-35, ATR CAM SHAFT, CRANE 1.6 ROLLER ROCKERS, I plan on keeping the stock ECM and going witha DIG chip any help with Injector size would be great. Ken
leroy
You probably should talk to Dig. I know he has done quite a bit with the 009 injectors. They would probably work for you. 50# injectors would give you a little more headroom. If you go bigger, you need Nolan's injector driver upgrade.
HTH,
Jim
SY756
I would recommend 50# injectors. That's what I have on mine and Dig's already got a real good base chip program for your setup. It may just need a little tweeking, like goes with any chip on different trucks, but that's about it. I don't think you will max those out with your setup.
