help quick with gauges
Raist103
i have my dash apart and was hoping that the light switch would have a blk wire for the ground. i am installing the indaglow gauges from ebay with a dimmer and blue green switch it only has 2 wires 1 red i guess power and a black ground? the back of te light switch on the pannel has a brown and white spliced together a big red, a orange, and i think a yellow. should i just use a 3 way conector on the red for red and same for black to brown/w=hite wires? or is there a easier place to add these wires in?
Raist103
also about the aldl cable from invisibill does the cig lighter have to be pluged in? i have a p3 compaq and one wire to the ground and one to the power of the aldl (top right and bottom right)
ed hess
race or get outta the way
don
i am here till 4-5 today. drive the truck with no dash over here and leave the light switch panel loose. Bring the directions and I can test your circuits with a meter.
ed
Raist103
got the gauges installed and ed helped me with the wires since my new volt meter was in the gn when stolen.
thanks ed
also i now have another problem, my speedometer and tach are only working sometimes and sometimes not at all and then some times it will just be slow and jump up right to the speed or rpm. any one got any ideas?
i tried taking it out and cleaning the ends on the back of the cluster and tried pushing it in harder and still nothing.
ed hess
don
I dont think you have the dash pushed into the plug all he way.
As i recall you should feel a positive engagement. Make sure nothing like other wiring is getting in the way behind the cluster.
ed
