chasing gremlins and i'd like to know how to properly delete the pcv valve system. i'v seen a lot of vehicles in the "who has the most clean under the hood" post that have deleted the pcv system.
is this correct? : cap off the tb and remove the tube on the valve cover and replace with a breather filter like on the driver's side vc. if this causes problems i can always put it back. this will not be permanent unless i don't really need the pcv set up. thoughts please. tia
