Help with code 43
Espritmike
I just put the motor back together and started it up.and boom......code 43. I put a new knock sensor and torqued it down to spec when I did the motor ,but, I dont think that is the problem. It sets with just the key turned on. meaning, if I erase the code, turn the key on, it comes right back. I even plugged another igniton module in (just the 4 wire and the module body grounded to the neg. GMs years back but my mechanic and I are a little rusty. HELP !
leroy
Re: Help with code 43
Check for the correct part number...GM #10456549. Make sure memcal is properly seated. Check continuity on circuit 496 between ecm and knock sensor.
Jim
Espritmike
The knock senor is the only thing that is different between now and when the truck was torn down. I think I put an aftermarket KS in it. My mistake. I replaced so many parts with OEM , why not the KS I don't know. I have one coming from the chevy dealer today. I saw a previous post that talked about this same exact scenario abou 5 years ago here....
Espritmike
Here goes, I did get a Standard PN# KS7, I just got a GM # 10456549 as advised by a fellow lister here (thanks) I will now swap it over trying not to scratch up my pretty motor.We removed the bracket with the coil,egr solenoid and map sensor, pulled the fuel feed line and tucked a wedge inbetween the head and the line to push them back for clearance. All-in-all should take about 1 hour. then I'll recheck-
Espritmike
OEM Knock sensor fixed the code 43, on to next problem- intermittent stalling in park, and stalling everytime I put it in gear....
