help with code 45
berzerker
wookie
driving truck to work the other morning , running great start getting onto hwy , and engine started running really rough , bad stumble , vibration so bad that the engine and trans felt like there going fall out of the frame. limped truck home. checked codes with datamaster .only code that came up was 45.. rich 02 . after checking vac . lines. and running eng. for a little while longer the problem seemed to get worse and datamaster showed alot of knock retard at only 1100 to 2000 rpms in neutral . the exhaust fumes are so bad they make my eyes water and the engine does not like to restart after being shut off .
also anybody ran into problems with killing mech . fuel pressure gauges , i've had two die on me in just 5 months time . have an earls 12'' braided aeroquip hose plumbed into shradder valve and gauge . zip tied along abs poportioning valve
Jimmy
Banned
Re: help with code 45
I had a code 45 which turned out to be a busted diaphram in the FPR.See if your oil smells like gas.
berzerker
wookie
i've checked my vacuum line at f.p. reg . slight smell of gas but not strong or wet from gas entering hose . pulled my plugs from # 1 & 2 and both wet . the last time it ran this rich is when i did'nt have the low impedance drivers for the injectors put in the ecm when i first fired the brand new engine . checked the oil did'nt smell like it was getting mixed .
