help with datamaster
sychris
i thought the truck was finally running great until i plugged in the datamaster . it says im gettitn spark retard all over the place mostly at like 25TPS% . it seems to go below 4* when i get on it, but when im just cruising around im getting alot of spark retard .wtf . stock chip , stock turbo , full exhaust , intake with cone filter , shurflo intercooler pump thats hotwired on all the time ,new plugsur6 and wires accel. how do i figure this out . i dont even want to take it out anymore cause of the spark retard . it feels like it runs great and pulls strong and i dont hear any detonation . http://www.mediafire.com/?bp3ww7m8e8ihrs6
sychris
Re: help with datamaster
http://www.mediafire.com/?vh30vw20wsu25q2 http://www.mediafire.com/?v6zja2rfvgp1rlr
carVSsuv
I can see your datamaster but I had an issue with my truck as well a while back.. I thought it was good and just got a lot of retard.. So I went to check the distributor and had a fellow syty guy in AZ bring over a dist. and then we couldnt time it. the balancer spun. Once I change out the balancer I saw that the timing was off and there was no way of fixing this with the stock balancer being bad and I had to replace it and set timing again
sychris
here is some more if anybody can look http://www.mediafire.com/?t84l5831ejdbq5d http://www.mediafire.com/?t84l5831ejdbq5d .
randy merritt
Have you double checked for false knock? Look for anything that could be hitting the block. That is my best guess for the RPM/Boost range where your knock occurs.
sychris
ill look again but i dont see anything . would my high ic temp be causing it . i have a cone filter by the battery and it gets hot . should i try piping it to the other side or something . my intercooler goes through the normal lower radiator and then it goes to another radiator where the a/c condenser was . how do i know if all the air is out of system
Might be false knock. Look at your graph. There are times when you have quite a bit of retard and others when, at almost the same throttle, you have none. Have you checked vac lines?
Flyin Ryan
hated cuz he drives fords
check to make sure no trans or fuel lines are banging the frame.. cut a rubber hose down the side and slide it over the line by the frame and see if it goes away or not
