Houseofperformance
switchhappy!!!
started up my new engine, and took a dm file of it idling and reving it a bit on standstill till it´s warmed up.the engine is a vortec built with bigger valves, 412 cam, 50´s
I noticed my o2 readings are a bit low on initial startup (fp was set to 35psi), once warmed up (closed loop) the s-term is in the 80´s range (does that mean the ecm ist trying to take out some fuel?) and it has troubles keeping the idle in closed loop ( stalls after a while), otherwise it´s running fine.
maybe some of the gurus can take a look at the file and tell me if i´m missing something.
I tried to tattach the file, but it doesn´t work.I can send it via e-mail.
thanks
thanks
