Help with KR and Turbolink
tbauer03
TRBOBOX
I have a couple of Turbolink runs saved on my computer and it is saying i am running really rich o2 thing overs around 950 and has gone above 1000 and i am getting some bad kr at shift points especially 2nd to 3rd gear. It gave me a overboost Mal code too which really scares me. I have a couple stock runs, and a couple 160 degree with hot wired ic runs. The lower IAT did not help at all which leads me to believe it is the fueling or false knock due to a bad motor mount. If someone would be willing to look at these runs and give me a hand it would be greatly appreciated. I was actually seeing better runs with the old thermostat. and i never had an overboost code until the hotwire and thermostat.
leroy
Ted,
There's nothing wrong with 950-1000 mVolts during WOT. The knock retard spike may be the converter locking, instead of the 2-3 shift, and is common. Sometimes it's converter noise (false knock), and sometimes it's real, due to higher engine loads.
Overboost can be difficult to deal with when you have a stock wastegate, but if I remember right, you have the stock exhaust. It could be a fueling issue, leaks, or a sticky wastegate.
I'd recommend a fuel pump upgrade and an adjustable fuel pressure regulator, before you beat on it too hard. Maybe we can get together and hook up the wide band to see what's really going on.
Jim
