help with new motor clearances
Got a new shortblock and want to know if when i put on the heads, should i check the clearance between the piston and the valve or do our motors not have an issue with it. I dont know the deck height on the block but the piston is just below the deck almost even and the cam is .505 lift with 2.02 valves. using .040 cometic head gaskets. any opinions would be appreciated
Re: help with new motor clearances
Yes, check clearances, Just one cyl should do it. Note: Before you set the heads on take gander at the orientation of the cutouts in the pistons. Do they align with the intake valves? A member here had an engine with the cutouts in the wrong orientation (assembly error) and the intake valve hit.
your short block has been checked. there was plenty of clearance with the brodix 2.08 valves so the 2.05 vortecs will not be an issue.
