Help with running a muffler or no muffler.
  • No muffler straight piped all the way back.
    Votes: 3 33.3%
  • Must have a muffler (please reply with your suggestion)
    Votes: 5 55.6%
  • Run a muffler with a cut out (please reply with your suggestions)
    Votes: 1 11.1%
  • Total voters
    9
  • Poll closed .
Ok lets start with the mods I have on my Ty.
Ultimate gauge style T116 to T224 (50lbs injectors? not sure yet), MSD 6AL2 with cap rotor and wires, NGK plugs, Alchy Control meth kit, Walbor fuel pump, BBK throtel body, Kennie Bell upgraded W2A set up, Hot wired W2A pump, RPM Stage 3 turbo, 3 in cobra elbo with cold air filter, Blitz blow off valve, Silicone vac kit, Brand new built 700r4 (for up to 550hp race shop says) with 3000 stall hughes, Brand new rebuilt front axle all Yukon parts, S15 4x4 front drive shaft ( same as jeep shaft), Battery moved to back,
Thats what I can think of off the top of my head.
What I would like to see is if I should run a muffler or not. I live out side vegas so I do not have to do a emission check. I just upgraded to a RPM stage 3 turbo and I want 3" piping to the back.
If you think I should run one what muffler do you suggest that sounds pretty mean and not like a ricer :lol:
Thank you for all your help.
QuinnSY
Re: Help with running a muffler or no muffler.
Its a stock long block though? If the cam is stock you may get away with a straight exhaust. My truck has a fairly aggressive cam and with an open down pipe I can barely hear myself think, and with a muffler its still very aggressive sounding. Adam in FL has a stock engine with a straight exhaust and it sounds just right imo.
Yea everything that I know of is stock. Some said not running a muffler will cause the turbo to spool really fast and and wear on the bearings shortening the life of the turbo. But I dont know if that is really true.
Thank your for your info.
SY2455
70's Veteran
If they are still around get the RPM 3" cat back with a muffler. Nice sounding and straight thru flow.
Logan
I have 3" exhaust with a Borla muffler and it sounds great. Not too loud, aggresive but not annoying or so loud that it says "look at me I have a loud truck and a little d**k." haha.
Same as you, stock long block. I have heard (haven't verified) that open exhaust can cause boost creep if you don't have a good boost control set up. I have the ultimate chip as well and I know it controls the boost via the factory equipment but I haven't verified how solid of a set up it is. I have yet to really lay into my truck yet.
teamvortec
My typhoon has straight 3" exhaust no muffler and for a toy I thinks it's fine, for a driver no way.
wexy21
You're Boosted!
I have a Borla muffler (I think?) and also an electronic cut-out. I'd say, if you are wanting the best of both, then get both...you can with a cut-out. I can go from loud and almost annoying to quiet almost dead in seconds. In town I'll have the exhaust open, but on the highway with it closed it's nice and smooth. Quiet enough to enjoy the stereo. :
killa66cam
RIDIN DIRTY
I plan to run both, a muffler and a cut-out. Like wexy21 said, best of both worlds. Muffler opinions will vary widely, but get something with a straight thru design...no 40 series Flowmasters. I am looking at using a Dynomax race bullet, if I don't find someone selling a used RPM kit on here.
Cam
Damian
Dynomax TurboXS muffler here and I have turbo back all 3". Sounds great to me.
Syclone#2960
What ever it takes!!
anybody running a corsa muffler? driving without a muffler is beginning to get annoying.
Darin
electric cutout is the way to go.
I ran one on my old Colt w/ 4G63T in it, and it made all the diff in the world. 3" to cutout, close cutout and it ran through the stock exhaust.
