JayLo
Sir Boost-a-Lot
I'll try to keep this brief. I?m MegaSquirting my Syclone (in another thread) and would like to start out with the stock spark tables for baseline tuning.
Another member was nice enough to post this (thanks leroy):
http://sunflower.com/~leroy/P4/BBZB%201580.htm#F1
This is very helpful, but only part of the story. I found this calculation that the PCM makes when determining spark advance:
"Spark timing advance calculations are the sum of the following terms:
Main Spark Advance Table (*F1*)
Coolant Temperature Correction Table (*F2)
EGR Correction Table (*F4*)
Power Enrichment Spark Advance
Spark Advance Boost Table (*F3*)
Minus the Following Bias Values:
Coolant Advance Bias (*KCTBIAS*)
Manifold Air Temperature Bias (*KMATBIAS*)
Boost Advance Bias (*KBSTBIAS*)
Spark Advance Run Time-out
EGR Advance Bias (*KEGRBIAS*)
Malfunction 32 Test term (*KKEGRSPK*), if applicable."
My question is, what are the variables that are subtracted?
More specifically, how are they calculated?
Is there more supporting documentation that I am missing?
If this is proprietary information, I understand. I?m not trying to deconstruct an ?Ultimate Chip? or compete with any of the tuner chip manufacturers. I would just like to make as simple a spark table I can to input into my personal MS unit.
Thanks for any and all help.
Regards,
________
Live Sex
Regards,
________
Live Sex
