help with the phill long chip
gjp
another post whore
Just got my Phill long 50# chip. V5. Not 100% sure how it works and what the setting do. It has 2 adjustments, one one the chip and one on the black box. I just dont want to blow anything up. The instructions are not that clear. Please help thanks.
I sent Phill a PM but I understand he sometimes is buisy.
gjp
another post whore
Re: help with the phill long chip
and what does the top knob do. What settings are there? thanks
cloneman315
there should be a lot of settings didnt u get a sheet with your chip?some are low timming and some are high timming and fuel changes
gjp
another post whore
yeah I got that. it says fuel, timing. I dont understand the +1,+2,+3.... Fuel and the difference between low and high timing. Sory if I sound dee,dee,dee but I dont get it.
cloneman315
it gets richer as u go higher in the numbers,and the low timming would be for like say pump gas and the high timming would be for race fuel
bezerk
use a datalopgger when you test out a chip, that's why it has more settings.
use a chip, and just try the fastest settings can kill your engine
gjp
another post whore
thanks. So obviously I want low timing. And adjust to keep the O2 in the 800-900 range at wot?
gjp
another post whore
Ok I pulled the ecu out and put in the chip. The old chip goes in with the tab going toward the ecu board correct. The instructions say it goes down so I guess that is what it means. it fits tight in there, but it fit. Cant wait to start my truck. I should have my rebuilt TB by friday so this weekend sy 411 might be back on the road again. Looking at my mods, what should I expect out of it now. Hopefully I can squeak into the 12's.
