hesitation and check engine light....
5678TA
hey guys, so my ty was running like crap so i changed the O2 sensor. now she is running great but there is a hesitation when i floor it. and the check engine light is still on..
any ideas what's going on?? truck is all stock with a bunch of stuff replaced. fuel pump/filter, rotor, cap, wires, plugs, fresh fluids. i'm on a budget for the time being since i just dropped a whole bunch of money to buy the ty and insurance, rent, etc.. but in a month or two i'll be back on my feet. so please help with diagnosis.
thanks
the baPhoon
Re: hesitation and check engine light....
Need a little more info to help with the diagnosis. what code is it throwing...
5678TA
alrighty guys, after a month, i finally got down to purchasing an ALDL cable and ran DM. pulled FOUR codes!!!
I got codes: 15, 22, 43 and 44. HELP!!
15- coolant temp
22- TPS
43- ESP
44- lean O2
alrighty, please guide me as i'm fairly new to diagnosing with a computer. truck just got a new O2 sensor.
5678TA
When there's that many codes, I assume some got set while working on it. I clear them, and start over.
Clear the codes by removing ECM A&B fuses for 15 seconds, then put them back in.
Drive it until the light comes on, and check the codes again. Then begin the diagnostics. Otherwise your going to be replacing good parts.
alrighty, i'll give that a try. thanks for the help...
5678TA
ok so I cleared the codes and came up with only the 15.
15- coolant temp low
what does that mean? need new temp sensor? is there a way to check if they are working? I see there is two on sytyauthority.net
and i returned that TPS i bought... Thank you very much Dave!!
5678TA
NO MORE CODES!!!!!! THANKS DAVE!!! and SyTy.net!!!
i found $20 in my pocket so i just went out and bought a CTS. the problem turned out to be that so it worked out nicely. now i just need to replace all the old 1993 ignition parts and get it running prime..
Thanks Again!!!
-Hogan
