pinellas50
New Guy
Yup, another thread on this topic.
Rant: Let me start by saying that I have been researching for days if not weeks on this. I have found thread after thread about similar topics. However, there are many that are really bad about updating their thread to say what they found. Not ususally the "hardcore" folks that I see on here all the time. But I would say that as much as 60% of the threads never contain the answer to a person's problem. This gets frustrating for the person searching..............You know who you are.
That being said, I am hunting down what is normally just an off idle stumble. However, I sometimes have a weird idle that lets the truck stall when you put it in gear and sometimes it's kind of jerky just cruising. I took the truck on a trip on the highway a few weeks ago. When I got off the highway I found that part throttle stumble turned into a part throttle dead spot......it was like there was no thorttle input for a split second.
Ever since I got the truck, with the windows up, you could always hear a hiss in the engine compartment when there was low boost. I always thought it was normal. You can start to guess where this is going..........
Well, I began thinking about just throwing parts at it like many others have done. I'm working on getting Datamaster but I don't have it yet. I did a paper clip test and got no codes.....well it just kept flashing 12 at me as long as the clip was hooked up so I guess that means no codes from what I read. I was getting ready to start with fuel pump, distributor, coil, MAP, etc.
Well, today I got around to doing the bike tube test. I found 2 big leaks. One is the normal TB shaft so I will have to go about adressing that. The other was a large vacuum port on the back side of the TB. It had just a large rubber plug secured with a metal band. I found that it was completely split open on the bottom so you couldn't see it. All the other vacuum lines were replaced with the silicone lines I got on here. I wanted to mention that rubber plug because I never read about that coming up as an issue before. Or mabey it's just so obvious to most that no one bothered to mention it.
I'll start my research on what to do about the TB. Let's see how many dead ends I find again. :roll:
Further bulletins as events warrant. Warning, this thread may get drawn out over some time as I don't have the kind of green laying around to put on part after part, one after another, trying to figure this out.
