high idle (code 42)??
socalblue
I picked up the ty yesterday and drove it around today, I am loving it, no problems ...so I thought. I decided to drive it around one last time before putting it away this time with the diacom linked to the ALDL connector. Well I went into a parking lot put it in park, and linked the ALDL connector with the Diacom laptop. Gave the motor a few revs just for the hell of it to check the rpm gauge. Looked good so I was about to take it for a drive BUT after I shifted from Reverse to Drive, all of a sudden the ty started idling high around 2k...I cruised home on idle, and checked the code with the Diacom and got a 42 code.
I guess my question is can hooking up the ALDL connector to the diacom cause something like this to happen for any reason (Maybe because I had the ty running when I hooked it up)?
Could my throttle have just stuck partially open (checked appeared ok)? Would that still put out a 42 code though?
The ty ran fine before I hooked up the diacom laptop to the ALDL connector...could it just be coincidence?
socalblue
Re: high idle (code 42)??
Well I cleared the ECM (took out ECM fuses) to see if it the prob. was just a fluke. But it's still idling high. And just now I noticed a small leak near the thermostat to hose...
Any suggestions/what to look at guys? :(
socalblue
Third times a charm, seems like the high idle went away....and the 42 code disappeared too... :tup:
JustBeachin
Plays well with others
Not a coincidence...You were running in ALDL mode, you needed to select Mode, Normal, then it would have idled correctly.
socalblue
Hey Doug yea I figured it out, when I hook up the ALDL connector while the ty is running it does that...I turned the ty off plugged it in then started it and no problems...had me scared for a little bit hahaha
