High Idle With Datamaster
ZavzTy547
Senior Member
I know search owns-When I hook-up Datamaster my Idle shoots up to 1250 and stays their.
Goes back to normal when unplugged. I get no codes.
Could it be a faulty TPS or IAC or?
93ty475
Re: High Idle With Datamaster
sounds like you're entering diagnostic (aldl) mode...when you enter aldl mode, it energizes all the ecm controlled relays and solenoids such as the IAC, hence your higher idle ....try it with your ignition on and engine off...see if your check engine light displays any engine codes or a 12...if so, then your in aldl mode....This used to happen to me when using turbolink....whose cable are you running....also could be a laptop issue....could even be an ecm ground issue....
ZavzTy547
Senior Member
I'm using a moates adaptor, it's the only cable that works with my newer laptop and datamaster. How do I get out of diagnostic- adle mode?
Thanks
93ty475
ZavzTy547 said:
I'm using a motes adaptor, it's the only cable that works with my newer laptop and datamaster. How do I get out of diagnostic- adle mode?
Thanks
Your cable might be grounding the aldl diagnostic terminal "B"....turbolink told us to cut an orange wire in their cable's black box ( module) to keep from grounding the "B" terminal....the only two terminals you should be using for data collection are "A" and "M"..."A" is ground and "M" is your data terminal...
SeattleSy#1255
Category 5 Conservative
zav, want to try my stuff and see if it works and changes anything? I can come to your place and bring your stuff while i'm at it.
ZavzTy547
Senior Member
93ty475
Thanks Man you were right on target!
Moates cable had A,M,B,D and E as outputs, which was grounding my diagnostic terminal. I cut B terminal with a pair of pliers and problem solved.
Big Jeff, lets hook-up before you leave...
