HKS SSQV BOV installation
TYHOGG
I never messed with the set screw on mine. The line feeds off the vaccum going to the booster. You will need to find parts at the local hardware store. I used a 3/8" t-fitting, 3/8" female collar, reducer and 5/16" barbed fitting.
Baja Resident
Can you use the vacuum line that is behind the throttle on the front of the intake manifold? It has a check valve on it and it runs into the charcoal cannister.
Ian Turgeon
Cascading Inspiration
2 places on a stock truck you can put it.
1: Add an adapter off the brake booster
2: Tee off the line from the front of the intake manifold BEFORE the big check valve thats near the FPR.
The adjust on the back is easy, and does change the characteristics of the valve. tight means it wont crack open as easily, loose means it will let go farily quickly. I have keept mine as loose as it goes w/o a problem.
