TYTILIDIE
METH HEAD
Got some problems with a Hobbs switch. I am working on Turbotyphoo69's Ty and am pretty much done with it. We installed the ATR double pump unit on the truck and today I finally got around to installing the indicator light in the gauge pod. Well, it doesn't come on. I hooked the switch wire up to 12v+ and the pump kicked on but the light did not come on. I tested the light off of the battery and it does indeed work. So I need to really verify this thing is working. I am suspicious that maybe the Hobbs switch is dead. Where can they be purchased and how much do they usually go for?
My other thought is this, I read someone wanting to use code 59 to run the second pump, this I can handle apparently using the stock boost control solenoid wiring. If I were to do that, what wires would I use from it and where would they go?
