Holley Dominator Fuel Prime
tbauer03
TRBOBOX
Its been months since I had to stop this Holley Dominator install because I have been relocating. But when I last touched it I was finishing up the wiring and starting with the software. Couldn't get the fuel pump to prime and I left it at that.
Today I knocked the dust off and put a voltmeter on the green holley fuel wire. I get 3 volts immediately when the key is switched to on and it holds at 3 indefinitely which is never activates the pump.
When I disconnect the green wire and jump the line headed to the pump with 12 volts it kicks on just fine.
I noticed on the ICU setup screen there was a setting that says enable fuel prime that I didn't check. Is this the problem? If so it asked for a percentage what should that setting be?
I didn't think I would have needed this because below the startup setting the fuel settings has the fuel pump prime set for 5 seconds.
Any help pointing me in the right direction would be greatly appreciated I haven't attempted to crank until I get this figured out.
Thanks
0966Sy
Code what?
I haven't messed with the Holley but I know BS3 uses a ground control to activate the relay. May want to confirm what the green wire should be
Sean Krupa
Moderator
Re: Holley Dominator Fuel Prime
Hey Ted,
Make sure you have the Green Holley Fuel pump wire goin to the Factory Fuel pump relay on the Firewall (Drivers side). Select "Enable Fuel Prime" and set it to 100%.
Any other questions, feel free to ask, as I just got mine running great on the Dominator. :tup:
tbauer03
TRBOBOX
Thanks for the help I removed all the relays when I took out the wiring harness. I still have them I'll just have to rewire them.
randy merritt
The green wire should be able to directly power a fuel pump as long as it is under a 10 amp draw. You do not have to use the factory relay if you don't want to. That wire should output 12V under the "prime" condition. I plan on removing the factory relay and using the Holley to directly power my fuel pump when I redo my wiring in the near future.
The statement above assumes you have a fully terminated harness with a built in relay.
autoaddictions
a relay cost 5$ please use a relay.
tbauer03
TRBOBOX
Thanks for the help I dug my old fuel pump relay out of storage. Just want to make sure i hook it all up ok because the factory harness is no longer intact.
I gather that the green/white wire is the trigger which will connect to the holley green wire. The gray wire will go to fuel pump, the black/gray wire will go to ground and the orange wire would go to a switched ignition power.
Is that correct?
tbauer03
TRBOBOX
I used the two ign fuse locations in the cab to power the dominator red/white wire and the holley digital dash. Is there another good source to tap into for switched power?
Sean Krupa
Moderator
You can tap into C101 the little white connector by the ECM harness for switched power. It's Cavity C or H. Pink wire.
tbauer03
TRBOBOX
It primes now after making that switch in the computer. Haven't added another relay.
Do I still need another relay? That green wire does come from the Holley relay.
randy merritt
No. The instructions say the green wire can handle up to 10-12 amps. If your fuel pump draws less than that, it can directly power it. If you want another relay, you can certainly add one though.
