Home-made Exhaust Manifolds
  • NO
    Votes: 0 0.0%
  • Don't waste your Time
    Votes: 0 0.0%
  • Get a Life !
    Votes: 0 0.0%
  • Total voters
    2
vortecfiero
I made Flanges (CAD) to match the exhaust port from 1/2" mild steel
the Primarys will be made from Schedule 40 NSP 1.375 ID and are about
34" long.
more info at this site
http://www.sdsefi.com/techheader.htm
I have used the theorys of Headers by ED for many years and sets of
headers for naturally asperated engines, the theorys seem to work
but on a turbo, I'm wondering is the length is neccessary. Both Tom
Monroe's and Corky Bell's Book seem to agree on the lenght issues, if
they fit. Having witnessed the hay-day of F1 turbos making outragous
power from 1.5 litre 4 cyc engines most of the pics show very long primarys
My Collectors will be 2" because since the engine fires from one side
to the other, I dont think there will be a flow problem and I dont want
a large change in Diameter which would slow down the velocity
The Velocity Numbers (250 ft/sec max) indicate that the 1.375"
primarys will support 100 hp/tube (600) and the 2" collectors will
support 220 hp/tube (400)
the whole idea (general consensis) to keep the velocity up and the
exhaust pulses arriving at the turbine at equal intervals
As far as the length goes, 32 to 35 inches seems to be the neighbourhood
but any Input would be welcomed
any pics I could find of Cosworth or McLaren engines show small long
Primays and tight IN/OUT ratios at the collectors
My turbocharger will be mounted High, over my transmission, with the
turbine portion centered on the engine
stage 1 will be 5 lbs boost through the the stock CPI Intake with a Rising
Rate Fuel pressure regulator
stage 2 will be 7 to 10lbs, a syty intake, injectors, ECM etc and some
sort of simple A/w intercooler
Stage 3, pistons etc and more boost and ... (TBD)
GOTSWRV
Do you have a good source (low cost) for Weld Els? The only place I could find around me ended up costing more than I expected. And top top it off they don't have much to choose from. Tried searching all kinds of crap on the net awhile back and got nothing close to what I was after. BTW Corky Bell's book is the best I've been able to find so far.
smeagol
FWIW, Duttweiler is a proponent of short exhaust lengths to the turbo, with direct (as possible) shots from the exhaust at the housing. This would seem the best to me, as you'd have the least turns necessary, leading to less heat lost through the manifolds/headers, and kept in the exhaust & used for spinning the turbo.
Just thought I'd throw that out.
Seems different than what I've seen in the OEM turbo diesel world (stating this since I'm exposed to that heavily). I'm not sure how much testing is done as far as performance goes there though. Most of it seems to be geared towards packaging first, efficiency second, in those applications.
Ian Turgeon
Cascading Inspiration
this seems to be in the wrong area, unless you plan on writing an article on making manifolds for syty?
vortecfiero
Brian you do have a point.
my thinking is that since I'm running relatively low boost, and will be
cruising most of the time, using boost in short sperts the engine will
still need a bit of "exhaust (except at the strip of course !)
scavenging and the collector effect" for efficiency and throttle response
and maybe runing cooler (internaly)
Interesting point about diesels, since they don't run much rpm maybe
tuning is not necessary. Also aren't they almost always on boost? But
then again, exhaust pressure and velocity "knows not from whenst it
came"
I have some old Hot Rod mags from the 60s, back when they actually
told ya why and how stuff works. Some of the articles written by MIT
people (not piston heads) get in to exhaust and intake tuning PROPERLY
but as usual packageing is the key obsticle
vortecfiero
GOTSWRV
I phoned around (here in Toronto) and found a supply store that
services the fire sprinkler, plumbing, gas industry, hydrolic (sp?)(etc)
industries. The steel bends are twice as much as regular exhaust bends,
but I'm hopeing they will last a lot longer as I only like to do stuff 5 times
At 90% completion my costs are about $400. CDN
I'm fitting and arc tack welding everything then taking it to someone,
who really knows how to weld, to tig it properly
vortecfiero
Sorry Ian...
I thought turbo charging a 4.3 and making turbo manifolds might be of interest to someone else (besides brian, gotswrv and 141 other viewers)
" Tech Articles
Submit your ideas and articles ...."
maybe you mean that it should have been posted in another section ?
next time I"ll ask the moderator
Ian Turgeon
Submit your ideas and articles for publication on sytyarchives.com. If you send writeups and images we can have someone create the page for you.
The idea for this section is for people to put together articles for me to put onto sytyarchives.com
helfmann
Turbo and exhaust thoughts
Brian made a good point in turbo technology especially regarding exhaust manifold designs & setups.
Some examples from Europe if you don’t mind to share:
Gasoline engine:
Opel (the German GM daughter) designed a turbo setup where the turbine IS PART of the HEADER manifold. Not only compact in design (safe $$$) also very efficient.
2000cc engine 204 HP
Diesel engine:
VW/Audi, leader in diesel technology*** did the same thing with their TDI’s (turbo diesel direct injection). Quite easy if you have an inline 4.
Lotec and other “Turbo Technik” companies go with a flat 6 (Porsche) or V6 (or V8)
with small primary tubes (high velocity flow) to get a very quick response and high revving turbine even at lower RPM‘s. If I look at the ATR headers, could be the same design (relatively small diameter tubes).
However, haven’t looked yet under a Subaru’s WRX hood how they did it with the flat 4.
*** If you ever come to Europe (preferable Germany) and you have to rent a car, ask for a Diesel!
No, I am not nuts, drive one of the new PD (Pumpe Duese = Pump Injectors) Golf’s with ONLY 110 or 150 horse and blow away EVERY 325/328 BMW by torque and power mixing the stinky diesel fluid with a 6 speed stick… or rent an Audi A6 TDI and enjoy going 242km/h (~151mls) in a DIESEL. Guy’s and Girl’s it’s FUN I always do it of I have to go to home country ;-)
M@
P
panic
Guest
I think there's a cross-over between thermal efficiency (maximum gas pressure/velocity to the turbine) and increased power at a specific high RPM. I would guess that for most apps, even most racing, a compact system has several advantages over tuned length:
1. lower cost
2. lower weight
3. easier to fit
4. less heat load under-hood (less radiating wall surface)
5. easier to fabricate - fewer curves
6. less change in shape between cold and hot, means less cracking
7. probably quieter
8. higher gas temperature & velocity to the turbine under most conditions mean more boost.
Unless the motor is very highly "scienced out" to a specific peak RPM (cam, plenum volume, manifold runner length, transmission ratios), I don't think long tubes are effective.
tyndago
Re: Turbo and exhaust thoughts
helfmann said:
Brian made a good point in turbo technology especially regarding exhaust manifold designs & setups.VW/Audi, leader in diesel technology*** did the same thing with their TDI?s (turbo diesel direct injection). Quite easy if you have an inline 4.
Lotec and other ?Turbo Technik? companies go with a flat 6 (Porsche) or V6
I have a copy of a Honda F1 paper from 1988 . 1.5 liter motor - 2.5 bar of boost- 685 hp.
In 1987 they were allowed to run 4.0 bar of boost........ 1,010 hp @ 12,000 rpms.
In 1986 , 1985 there were no boost restrictions...
They use not abnormally long runners on this motor. I have seen some stuff with some long runners - but I think it may be packaging as much as anything else.
I think the CART carts use fairly long runners...
Including the crossover on the Syclone/Typhoon , its a fairly long path from the drivers side to the drivers side where the turbo is.
On the diesel cars --- just went for a ride in a Mercedes 320 CDI.... over here for viability for emissions testing...... I read the CDI on the back - the guy started it - didnt notice it was Diesel - thought maybe it was just a badge. Soon as we were moving , I could tell it was a diesel. Then he got on the throttle and I was suprised how quick it was for a diesel. The CDI stuff is pretty cool - better than I thought it would be....[/img]
