4C FED
Absolutum Dominium
I reconnected the battery a couple of weeks ago to upload the FAST startup program.
The following weekend I found the radio was dead.
After poking around I found that the Horn/DM fuse was popped. While troubleshooting I could see a constant 7 amp draw with nothing on.
When I disconnect the fusible links behind the alt. the draw is about .5 amps.
Today I spent most of the day chasing this gremlin.
Now I can hear something in the dash cycling. It sounds like a re-settable fuse turning off then on.
When I put my DVM between the + term. on the battery and the + battery cable I'm drawing 1.7 amps, then it jumps to 20 amps and drops back to 1.7 amps.
I've pulled the horn relay and that didn't make a difference.
I fixed a short at the dome light, no difference.
Here is something that I noticed, maybe a clue; With a good Horn/DM fuse, the interior lights work normally (door open, lights on. doors closed, lights off). If the Horn/DM fuse pops, when the door is open, the underdash lights are on and the dome light is off. When the door is closed, the dome light is on, underdash lights are off.
I've left the battery disconnected for now because I'm afraid something is gonna fry.
Anybody have a previous experience like is or any ideas on where to look?
_________________
Rick
Sy#458
Galt, CA
<font size=-1>[ This Message was edited by: 4C FED on 2002-03-17 23:20 ]</font>
<font size=-1>[ This Message was edited by: 4C FED on 2002-03-17 23:22 ]</font>
_________________
Rick
Sy#458
Galt, CA
