horn dont work
sychris
it never had one, i got a horn from advanced and plugged it into the green wire by drivers headlight and grounded it to fender well and still nothing it dont work . am i on the right wire?
fauXGT
Brick Pilot
Re: horn dont work
Stock steering wheel? Pop off horn button & see if a wire is connected to the steering column. Don't pull too hard & break the spring lead attaching to the column. The catch in the horn ring buried in the column snaps & won't hold the spring wire.:2cents:
sychris
Re: horn dont work
On the inboard side of the column is a long connector with about 10 wires in it. Using a jumper, and a paperclip to make a connection, short the black wire to a good ground. Horn should sound. Or the relay should click. Relay is adjacent to the park brake release handle.
My vote is for a broken wire retainer behind the horn button. Very common. If the test above sounds the horn, remove the horn button. The bottom two pics in this post show the horn button contacts, and the little tabs that get broken.
i hear the relay clicking when i press horn . am i on the right wire ?. is it the green wire by driver headlight?
neildemo
Administrator
Re: horn dont work
Where would we be without the Knowledge of Dave...Thanks Dave prob the 10th time this year. :)
hatrik8
I found out my horn isn't working last time I drove the truck. Glad I stumbled across this thread :)
Sent from my iPhone using Tapatalk
