Horn problem
vinnieTy
TY # 1889
I cant believe i did this. I was at the light coming home from the hooters meet on sunday a little tired been on the road for a few hours and i went to pull out the horn just out of curiosty to see what was behind it. Yes i am an idiot any way the horn comes off and so does the black wire, but the black wire didnt come off the actual horn cover it broke from some where inside that little hole it goes into. Now i put the cover back on and no horn, DAAAA What the hell holds that black wire in that hole. It looks like a spring and maybe a clip. :(
ANy pictures or idea what the hell i need i would appreciate it.
thanks
jjorgensen52
NHSTE - I'm the only one!
Re: Horn problem
thanks
Mine has been off a couple times... IIRC the spring actually goes between the tab on the black wire and the horn button. I don't remember there being any kind of retainer
ty166
Re: Horn problem
if memory serves me correct, on the wire is a spring and a plastic sleeve , all held on the wire by a brass contact on the other end , the rest is probably down the hole you pulled the wire out of , might have pulled the contact off the end... but you'd have to pull kinda hard..... we're we alittle over served at hooters ??? lol
syclonekid43
Re: Horn problem
if the wire and black clip came off in one piece. then you broke the cam in the colum. if thats the case you have to pull the wheel off and take the colum apart to change the cam switch
vinnieTy
TY # 1889
Re: Horn problem
If i pull the horn button off the steering wheel the black wire comes off with it. At one end of the black wire is the female connector that is still connected to the horn button which is in my hand the other side has a spring with a copper head to it. That spring side of the wire was attached inside that hole some how. Is there a clip. I just heard bing then i noticed i had the DAM horn in my hand. Then i heard the people behind beeping becasue i had the green light. I tried to beep back that didnt work, HAHAHAHAHAHAHA:rotf: :rotf:
syclonekid43
Re: Horn problem
on the black piece of plastic there should be a nipple on the side of it. that black piece is just push and turn and it locks into the cam switch. most of the time when you just pull it out it breaks the cam.
thats what you have in your hand. look at the top right of the black plastic. see the nipple?
http://cgi.ebay.com/ebaymotors/82-9...tegoryZ42612QQihZ006QQitemZ160061089485QQrdZ1
http://www.lmctruck.com/icatalog/cst/images/0117.jpg
if the case may be you broke the cam. look on this page. item number 1 is the cam. sorry best pic i could find of it. if the link dont work. go to www.lmctruck.com look under s-10 section go to page 116
kentuc
Re: Horn problem
I have repaired many of these by cutting a new notch in the retainer. You have to remove the horn contact ring to do this. A new one is only about six dollars.
