HORRIBLE IDLE AT START
sharky207
My truck is running really ruff at start. I have to sometimes rev it in order to keep it from stalling or from turning the infamous check engive light one. Are my injectors dirty? Do I have a bad sensor? No idea... help me
I've heard of this problem happeing before from other guys on the page but i need some answers. thanks
jwaller
Evil Genius/SyTy Guru
Re: HORRIBLE IDLE AT START
sounds like your O2 went to the shitter. that would be the easiest thing.
Hu Ryde
When was the last plug wire change or plug change. Or in other words last tune up. What code have you been getting?
sharky207
the only time the check engine light comes on is when the idle is low and comes on for less then a minute. its doing the same thing that it did before i got my fuel pump changed
Hu Ryde
Sharky, plugs have been known to foul out and no longer provide adequite spark especially the AC's in a short amount of time. Try some NGK UR6 plugs and see what that changes. Wires are ok unless they have been heated and brittle. Also check the connection of plug and wire, sometimes they can seperate from the wire and be stuck on the plug. Have you ever done a Top Engine Cleaner? If not it's cheap and helps alot, make sure to do it before a oil and plug change. Good luck.
sharky207
well i just cleaned my throttle body and know after driving i put it into park and the check engine light comes on within seconds. I have ngk's in know and i checked all my connections. If plugs or wires were dirty why wouldnt it mess up all the time? Im getting code 35 IAC....?????
Hu Ryde
Probly nothing serious, check for vac leaks, check for a stuck iac. It's probly the iac because it is related to the TB. The iac is what is attaches to the TB under it, the electrical connection goes to it. Spray carb cleaner in it once it's all apart. Is the idle better or worse? What about the rough start?
sharky207
everything still sucks as bad as it did before i cleaned my tb. Exept for the addition of my check engine light coming on when in park. What do you think about replacing the iac? how much?
thank you- John
manitoufs
John -
Unless you know what your IAC number is at idle at normal operating temp, you are shooting in the dark. Hook up with someone with Diacom or Datamaster. There is no sense in replacing parts when you don't know what is wrong. You are just wasting money and time.
The IAC number (it should be between 14 and 45 approx.) can be adjusted very easily by turning the torx headed screw next to the throttle linkage. (It may be covered by an aluminum plug. You can pop it right out.) You can even do this without diagnostic software. You just won't have a firm handle on where you are.
Remember the KISS principle.
sharky207
so should i take my throttle body off and clean it from both sides? How do i go about cleaning my iac?
thank guys I appreciate the help
Hu Ryde
The IAC is on the bottom and is held in place with the torx head screws. Be carefull and you wont have to replace the gasket that seperates it from the TB. Clean with normal carb cleaner. Make sure the plunger is free of any debree, Good luck. Where are you located som maybe someone near can help or is willing to hook your truck up to datamaster.
Coloty
I have always removed the IAC with a large deep socket....size I think is like 1 1/4 inches might be wrong. I guess you can remove both the IAC and plate like is suggested above too. Carb cleaner/intake cleaner works well, just don't manually pull the plunger in and out or you will hose the IAC and need a new one for sure I already tried that :D . HTH
sharky207
im putting off taking my throttlebody apart until sunday. When driving my truck yesterday the rpm were going from 9-1500 rpm's all on there own?? Doesn't that have to do with the map sensor?
