Horrible Knock!!!!
Ok guys, I just bought my sy about a month ago and it is knocking like an SOB! It only happens when the turbo starts boosting, before that all is fine. Heres what I have for mods: Hypertech chip, 3 bar map sensor, 42# injectors. I have checked all the usual suspects out and everything seems to be fine (o2 sensor reading correct, timing, timing retard during knock, 92 octane gas) the only weird measurement I got was from my map sensor. I'm at sea level so it should read around 29hg but it is only reading about 18. Could that have anything to do with the chip? Any other ideas on how to get rid of this dang knock??? PLEASE HELP
Re: Horrible Knock!!!!
that is an interesting setup you have there. Most people go with the ultimate 50lb injectors combo.
If your chip isn't working correctly you would need another chip programmed for your setup to verify that the chip is working or not.
What are you using to read all the information that you are getting? Do you have a scan tool such as datamaster to look at this info?
No, I have a Snap On graphing scanner (I'm a mechanic) So what chip in your oppinion is the best? I bought the injectors off of ebay and got a pretty good deal :) so that is why I'm running those.
Ultimate chip is the best for ease of use and the amount of effort that has been put into the research behind the tuning of it.
You can also get many different board members to make you a custom chip fairly easily.
What is your current chip set up for?
See thats the problem, I bought the truck with the chip in it already so I don't know what it's set up for. Plus I don't think I've heard of anyone using a Hypertech chip, have you?
93ty475
You'd be better off locating a stock chip and stock injectors for now....keep the hypertech to use at a later date when you decide to run an emulator to tune your truck in real time....
SeattleSy#1255
Category 5 Conservative
I'm going to guess that your Hybertech chip is for stock injecters, so that in wrong.
I'm going to guess you Hypertech chip is a 2 bar, so having a 3 bar MAP sensor is wrong.
Having the wrong injecters, with the wrong chip, and the wrong MAP sensor is going to really mess things up.
Best thing you can do at this point is take stock injecters, stock chip, stock MAP sensor install them and start from there. I'd bet anything it'll run stronger with the stock setup.
93ty475
dhorsman2000 said:
definatly a detonation/ping.
These motors don't take too much of that....Start with the above recommendation, get datamaster (popular laptop based scantool), search and read this site until your eyes bleed and you should be ok.... ;)
Jimmy
Banned
:stupid:
Your scan tool probably isn't calibrated for a 3 bar map sensor and I know Hypertech doesn't make a 3 bar chip. So that is obviously an issue, Hypertech is not that great of a chip. Hypertech may have burned a larger injector chip for a custom application.
thaks for all the input, i'm gonna go back to the original chip/inj/map sensor and start from original and then tune the hell out of it.
SeattleSy#1255
yup, if you ever have problems, start with your stock baseline and go from there...espically if you got a truck that you don't know exactly what the previous owner did. Don't consider it a waste as if you decide to upgrade in the future, many chips piggyback the stock on anyway, use the stock injecters as well. Hold onto the 3 bar map sensor.
