How bad did I mess up?
jamnut
I installed my Walbro a while back & since I thought I was such a good mechanic & have done many, many, many in tank fuel pump install's on all kinds of vehicles I didn't do any research on here about deleting the pulsation dampner in the tank.
So my Walbro was installed with the pulsation dampner still hooked up. Now after doing some searches on some other stuff, I've seen a few things about removing the pulsation dampner. What are the draw back's of still having the dampner installed in the tank? I will be dropping the tank in a week or so as soon as I get home & my Hot wire harness gets to the house, so it will only take a few extra minutes to pull the pump, remove the dampner & hook the pump back up with some tubing.
Right now my pump is acting right, I've seen 65+ psi on my pressure gauge under boost. So it seems to be holding up for now.
Would y'all recommend spending the time to re-do it while I'm installing my hotwire kit?
MRKING
New Parts for Old Trucks
Re: How bad did I mess up?
I searched for "pulsation dampner" and never heard of that . I changed to a walbro 255 in my sy and had no problems . I couldnt pick one of those out of a pile of parts if I had to .If you get good pressure than the pump end should be fine . Ive been wrong before , but I'm trying to catch you before you drop your tank unneedlessly .
jamnut
The pulsation dampner is the little thing that your fuel pump outlet sticks into instead of using tubing. I found a few threads that say to remove it & hook the pump up with just tubing instead of just installing like it was stock.
jamnut
Here's a pic of it from the same thread.
TYTILIDIE
METH HEAD
From what I gathered when I did my FP, if you keep that part Im pretty sure the only draw back will be that you will not have access to the gas that makes up the difference in the bottom of the tank due to the shorter length. Heres my honest opinion though, if you can find a way to use that thing, Ild use it cause Ive had to replace 2 of those frigginhoses now and its getting old. Mine fall apart about every 8 months to a year. I really dont get why they didnt make a longer "dampner" or whatever the hell that thing is called for the kit. Im sure it s due to many different aps. :2cents:
jamnut
I have some submersible fuel line for intank install's. It's the clear type not the rubber type.
I might look into doing some kind of tank mod to the sending unit. On F-bodies in the tank there is a fuel pump bucket, the fuel pump has a little fuel line on top of it that pulls gas from the bottom of the tank & fills the little bucket up to keep the pump submerged. You can't use a Walbro for this application due to it not having a suction hose, if you run a Walbro on a 4th gen Fbody you have to gut the bucket so fuel can flow in from the bottom. But Racetronix makes a Fbody pump that has Walbro guts in it. It has the pickup for the fuel bucket in it. I may start messing around with trying to see if I can modify an F-body sending unit & pump assembly with the bucket to work with a SyTy fuel tank. That way you would be able to launch with less gas & not have to worry about your pump getting starved.
I'm running a sumped tank in my Formula with an Areomotive pump, I'm sure before it's all over I'll be running an external pump setup on the Sy also.
