How bad is this ?
nightdiver
I did a leak down test
Got two pistons with 35% and the rest are 22%
Time for the SRPs..........
Goodbye TRWs
2cold
That's bad. If the test was accurate its time to tear down the engine. Where was it leaking to, the case, exuast, intake?
2cold
I would pull the heads or use a boroscope to see if your pistons are burnt up. But it really doesn't matter, If your getting 35% into the case you are gonna have to pull the engine and rebuild it. You want to look for the cause of the failure too. It'd be a major bitch to rebuild it and blow it again because of an overboost problem. Unless you've got some high miles you shouldn't be seeing 35% through the case. That would tell me to look for busted ring lands, burnt pistons, etc. I've got 116,000 on my Ty and still have 4% leakdown.
