How do I get rid of HyperTech Chip?
SacDoug
This may be a dumb question. I just opened up my ECU and found a HyperCrap chip in it. The guy I bought my truck from did not give me any extra stock chip(s). Can I just remove the hypertech chip or do I have to have something to replace it with such as a stock chip?
gib74
Re: How do I get rid of HyperTech Chip?
You need to replace it with another chip. Nice to see another SYTYer some what close.
SBNova
Usually a hypertech chip has the stock chip (memcal) attached to it. It should be 1" wide, about 4" long andprobably have a light blue cover on it. Take off the hypertech, then install it where the hypertech was.
SacDoug
Thank you!
I just opened up my ECU again and you are right. The stock chip is attached to the HyperTech chip at a 90* angel. I removed it and installed my stock chip back.
I noticed a difference right away. The HyperTech chip was building a lot of boost at low throttle and rpm. I could take off like a bat at just 1/3 throttle from a stop light. The truck is much tamer at low throttle and rpm. This is a good thing since I really don't need all that power at just 1/3 throttle and it was killing my gas milage.
The big problem is that the truck would just lay down at high rpms and would not accellerate much at all. Once I got over 90 mph it was as if I hit a wall and the truck would hardly budge.
I just took it out for a quick drive and it accellerates smoothly all the way past 100 mph. The wall is gone. My truck now has a top end where before I might as well have just had the governor set at 90 mph. I will be very interrested in my next track numbers. Hopefully I will do better than 14.6 @ 92 mph.
Sy643
Just curious, does anyone know what would cause this? I have the same issue with my stock Sy. With the chip in it runs pretty good at low speeds, more boost but on top end it just won't go. :rant: Without the chip it runs good just not as much boost however it goes well over 100 with no problems. :D
I am still trying to tune my truck so I wasn't going to point a finger at an one thing just yet.
Anyone else have a hypertech story with their Sy or Ty???
Thank you!
jpalmer
Dave, the all-knowing Dave. He can even fix a hypertech chip :rotf:
mattw
You could get rid of your hypertech chip the way I did mine: Place it on the concrete floor of the shop, and hit it really hard with a 5lb sledge. Gone!
Don't do that.. They make perfectly good chip-carriers for chips that you burn yourself...
SY2932
Administrator
That's what became of mine after I realized that's what was in my ECM :roll:. My truck overboosted like crazy when I first bought it and I never could figure out why until I dropped the ECM and saw that the factory tape was cut. Heh, that was ten years ago last month...
