How do I identify L-35 heads?
Status
Not open for further replies.
JKsSyclone
I know this has probably been answered 100 times before but my brother is working for a salvage yard and he is going to hook me up. What do I need to look for. Thanks for any info.
ttdolson
The easiest way to tell a set of L-35's is to look for two tapped holes,
They are stacked on top of each other, and they are located between the exhaust ports.
Its the same hole that holds the knock sensor, on l-35's there's another hole below the knock sesor hole.
B
Blake
Guest
If this is true, based on the pictures on the link given, my 93 Ty has L-35 heads on it.....just noticed the extra hole while changing my plugs and thought, what the hell,never noticed that before....everything is just as it was stock on the engine from the intake down.
I have a new set of L-35s in the garage, I'll be going to those anyway. I'd like to get a good look at these heads when I pull them next year.
Blake
Tooky
Serious about performance
Do the 93 Typhoons show any trends to suggest they run any faster than the rest?
Tooky
Sigo did your Ty have L35s and/or was it one of the last ones produced?
Your 14.0 and 14.2 sound dead nuts on with what it was supposed to run.. The figure I have heard most often is right around 14.1 for a stock Ty and I know there are some that ran high or even mid 13s but it seems they are the exception rather than the rule.[/url]
ParTyBoy
Daron
Ok read the question the original poster asked, and then look where this thread went, and is going. Gonna stop the madness now...
Status
