How do I lower my front
blk00z28
Forced to by choice
Re: How do I lower my front
Not to dig up an old thread. But can you also drop the front by using softer, or shorter coil springs? (This is just a question..) Would that be an option over the torsion bar bolts, or spending the $700+ on coilovers..?
I wonder how lowering the front with the torsion bars will work with my diy front end limiters?
Black Knight
I Glow Therefore I am
How are you going to use a softer coil with torsion bar? Not many choices for our front suspenion, either one or the pricey other.
'JustDreamin'
Dream: 6LV8 Turbo Bravada
The problem with that theory is that only the 2wd trucks use coil springs.
The 4wd trucks use torsion bars not coil springs. And aftermarket torsion bars aren't readily available for the S10 platform (that I'm aware of).
A torsion bar is a spring, just happens to work differently. They're basically sections of round barstock (or tubing) with splined or other shaped ends to lock into the holding devices (in our case, they're Hex shaped). Torsion bars are also commonly used for anti-roll / sway bars.
And sadly there's no good way to change the rate of a torsion bar once its made. Torsion bar stiffness is determined by material properties, active length (distance between the fixed sections), and OD (and ID if its a tube type) and once its heat treated making changes to any of those is difficult (could grind the OD of the torsion bar if you had the right tools).
In summary, your choices are really only:
1.) Adjust the torsion bar bolts (which adjust the key location) and live with the ride quality.
2.) Swap to coilovers and be able to pick the spring rate(s) you want.
'JustDreamin'
blk00z28
Forced to by choice
Yeah, dont ask what I was thiniking when I asked that first question. lol sorry. I was looking at coil overs and forgot we dont have springs stock.
