How do u install a check vavle?
Syclone#2960
What ever it takes!!
I installed a check vavle between the BC solenoid and wastegate actuator.Is the correct way?Or does the BC solenoid need to be removed? :cry:
________
You tube ****
InvisiBill
You mean a "Grainger" valve? http://www.boostvalve.com/tech/IC_install.html The valve replaces the boost control solenoid, as they both do the same job. This is to modify the boost pressure that is seen by the wastegate actuator. The solenoid does this by bleeding off some of the pressure. The valve does this by staying closed until the boost is high enough to overcome the spring pressure and open the valve.
Syclone#2960
Re: How do u install a check vavle?
When installing this device should you turn the wastegate rod as short as possible and then control the boost with the valve?
