Re: How do you leak proof a motor?
Its especially easy with a one piece rear main seal motor....
Starting at the bottom:
1. Gasket shelac on both sides of the rear main seal to block adaptor gasket.
2. Gasket shelac on both sides of the timing chain cover to block gasket.
3. Tiny pencil lead size bead of silicone across the timing cover groove where the gasket between the cover and the oil pan reside.
4. Pencil eraser (or slightly larger) dab of silicone at the corner of the timing cover where it meets the block.
5. Same thing with the silicone where the rear main seal adaptor meets the block at the rear main cap.
6. Pencil lead size bead of silicone across the rear main cap groove where the oil pan to block gasket resides.
7. Gasket shelac around the water passages in the block deck surface and cyl heads (ppl wanting to argue can bite me since after ~12 kabillion small blocks and 4.3s done this way no gasket failures, leaks, world coming to an end, etc so I donwanna hear it).
8. Pencil eraser size dab of silicone at the corner of the head where it meets the block at the ends of the intake sealing surface.
9. Gasket shelac around each intake port and coolant hole on the heads.
10. Same deal as #9 only on the intake manifold.
11. Put intake gaskets on heads immediately after #8 & #9 so that the little ears on each end that meet with the end rails of the block squish the still we silicone.
10. Run a bead of silicone about the diameter of your pinky finger (less if youve got fat fingers and more if youre skinny) across the ends of the block over TOP of the ears on the gaskets that was metioned in #11 and keep going until you get to the end bolt hole in the head (where the intake bolts on NOT the head bolt).
Special notes/FYI:
A. With a one piece rear main seal motor if the crank has a groove worn in it from the old seal dont drive the new seal into its adaptor until it bottoms. Leaving it slightly "out" from where its supposed to be puts the seal lip on a fresh part of the surface on the crank.
B. When installing the one piece rear main seal in its adaptor it is critical that it goes in straight. If its installed unevenly it will leak...maybe not now but sooner or later it will. Lay the adaptor with the seal side up on the work bench, put some vaseline on the
outside of the seal, lay a 2x4 or similar across the seal and give it a few taps to get it started then drive it home with a BFH. If youre doing the worn crank to seal surface deal then it takes some practice to install the seal but not seat it all the way as trial and error is the only way to learn that one.
C. If youve got a harmonic damper that has a groove worn in it from the seal in the timing cover there are repair sleaves that are slipped over the outside of the damper hub and held in place with lock tite, silicone, snot, whatever and they are available from any parts store like NAPA (dunno if the chain stores like autozone carry them though). If you dont use the sleave on a worn harmonic damper theres a 99.9% (IMO and BTDT) chance it will weep oil out of the timing cover to damper seal location.
D. Water pump to block gaskets are fine with shelac on both sides and a side benefit is it holds the gaskets in place while you fiddle with holding a ~20lb water pump while trying to get the bolts started.
E. I very rarely use silicone anymore since I found some stuff called "The Right Stuff" gasket maker. Its a million times better but aint cheap as well as it having a short shelf life once opened but you can get it in a "kit" that comes with its own miniature caulking gun to apply it or it comes in a can that has propellant for you REALLY lazy ppl so all you have to do is push on the spout/tip and the stuff comes out on its own in a nice size bead. Ive never seen it at the chain stores but ppl like NAPA have it and Ive seen it on line too.
F. Gasket shelac on head bolt threads too.. Just be
sure to burnish the threads in the block and on the bolts then add 5ftlbs to your torque wrench when doing the final torque sequence then youre just like Nextel....done.
G. Pencil lead size bead of silicone on both sides of the T stat housing to intake gasket.
H. Center bolt valve covers dont require any sealer if you tighten the bolts starting at the inside and working outwards (you'll never get the old style perameter valve covers to not leak unless you weld them on so forget that).
