I am looking through the P4 document and for example..
I choose to look up the conditions of a code 35.
1. Coolant temp is greater than or equal to *KIACWARM*
2. Malfunction Code 21,22, or 24 are not being detected.
3. Throttle postion is zero.
4. The magnitude of the desired idle speed minus the actual idle speed is greater than *KKIADIAG*
5. Conditions 1 thru 4 have been present for a period of time greater than *KK35TIME*
Once Malfunction Code 35 has been detected, it will not be reset until one of the conditions 1 thru 4 above no longer exist. If *KK3STIME* is set to a value of 255, the associated timer will have a infinite value.
In #1 where is *KIACWARM*?, is there a location in promgrammer that I can see it? , what about in the P4 document?
The same goes for KKIADIAG, and KK35TIME. I am *trying* to read through the P4 but it would be nice if I knew how to look up things when I see stuff like.......
WHEN blablabla is less than KKKKDHH, is there some sort of index of these locations that you can find them with, or is there a search feature on promgrammer?
Thanks,
Scott
Thanks,
Scott
