how do you read a turbine map ?
vortecfiero
found these on Garretts web site and im trying to understand what im seeing
and how do i plot my engines turbine requirements ?
http://www.turbobygarrett.com/turbobygarrett/products/turbochargers.html
thanks in advance
Quickstop [UK]
Combating adversyty.
Re: how do you read a turbine map ?
The top one isn't a turbine map per se...
You need to see a map with the efficiency lines - it looks like an island in the middle.
There are a lot of variables but you need your engines volumetric efficiency, volume, max flow rate in cfm for starters...
BMW forum....not a bad description
