How do you remove a stubburn lower intake?
ZavzTy547
Senior Member
I've been trying to figure out how to remove a stubburn lower intake manifold without damaging it.
All the bolts are out, it just wont budge. Any tricks?
Thx Mang.
Zav.
Quickstop [UK]
Combating adversyty.
Re: How do you remove a stubburn lower intake?
Put some bolts into where you would mount the upper intake and use the crane or someone else to lift from there? Or pry it with a gasket scraper all around?
Timbo
SyTy Stalker
...Or tap on it with a rubber mallet. I'd try putting some upper inake bolts in and lifting first, like Quickstop said.
1madgumby
Took mine off A bunch of times, take A small stright screw driver under the front of the intake, pops right off.
Norm
Any chance the valve covers are holding it down?
Quickstop [UK]
Plug all the ports then fill it with water and freeze the block. The expanding ice will pop it right off.
jwaller
Evil Genius/SyTy Guru
use a razor knife and cut the RTV on the front and back of the intake and then you can pry it off with a pry bar off the front drivers or pass side against the valve cover.
Z SKI
x2, the RTV is gluing down the front and back.
Ratfink749
Greasy and proud.
I've always used a large prybar... over the top of the water pump and under the front lip of the intake. Sometimes under the thermostat housing, sometimes under the lip of the manifold if its accessable. give it a little pry and it usually lifts right off. (of course, I'm using a 36" prybar... so it makes it easy) Sometimes that RTV holds REALLY well.
ZavzTy547
Senior Member
I totally over analyzed this...
Sy1219's method of using a small straight screw driver under the front of the intake, did the trick.
Thanks Peeps.
Z
