You have gone that far i would just replace the entire dizzy unit... Have you ever had the dizzy out before? It would be an awesome idea to replace it due to possible a worn out dizz gear?
Steve
You have to take the distributor out of the engine, remove the roll pin that's thru the gear at the bottom, slide the dist shaft out the top, then the pickup coil will come off.
