how does this MSD harness get used
s_blazin
maybe i'm missing something here, but i just don't get it.
so can someone explain to me how this works.
this pic is of the stock coil plugs
this pic is of the stock coil plugs on the engine harness and coming from the distributor
and this is the MSD plug and play harness, notice that the plug is male which i would
assume would plug into the stock coil plugs on the harness and dizzy.
so my question being, if you plug the MSD harness into the stock plug on the engine harness,a dn for the dizzy harness and plug the other end of the MSD harness into a 6 series box, how do you then plug back into your coil?
or is this harness only used if you are planning on using a non stock coil say like the round style or something that only has terminals for a regualr old round connector.
i guess maybe i'm missing something here, i just don't understand what the use of that harness is for or how it goes?
sy#2921
BAMF
Re: how does this MSD harness get used
that msd harness is missing two wires and the connector that would go back to the stock coil
Norm
Your going the direction I came from. I had a msd harness and was returning the ignition system back to stock.
This looks very close to the wire I found tucked up in my passenger side fender... I wasnt able to see what it is connected to...it seems like its connected to nothing...it doesnt seem like it'l come out easy so I just left it there....is this a normal location where someone would stick an MDS box? ill take a pic of the wire some day soon and post it here...all I see is the part that looks like 2 electrical outlets stacked on top of eachother...
s_blazin
um i have never seen anyone put their MSD box in the fender (except for me) i did mine like that because i think it is ugly and don't want to look at it. i will add a little part in my build thread of how i did it
Norm
Mine was put inside the fenderwhell as well, hidden behind the cold air box, you didn't see it at all. Was a nice install. And didn't see any real benefit to having a msd. I still have it,just didn't use it after I reassembled the ty.
cloneman315
only one plug goes to the coil after the msd is put on."the orange and black wires only"
warmpancakes
I was installing mine last night had to call aj as I was sure I was missing a connector,
