Ok, well im going to be installing a set of stock manifolds and crossover and a stock downpipe on my GT and was going to run a stock turbo and plat around with that till i get the LS1 built and installed.
But i have been thinking about going with a 20g upgrade instead and wanted to know juts how much differance it will make over the stock turbo. I will be using a CPI upper and lower intake that has been extrude honed and willbe converted over to a multi port set up. I am also going to be running a stock Sy/Ty ECM with tunercat R/T software. I cant decide weather to run the stock wastegate or an external gate, the internal would be easier and i could raise and lower boost in the program( I think).
So basically for you guys running the 20G what kind of power increase is it worth and what boost number are you running?
Thanks
Thanks
