how much boost with 9.5:1 compression?
Syclone#2960
What ever it takes!!
I running 9.5:1 diamond pistons on my new build with vortec heads, studs, turbo time custom cam, alky & eldebrock intake.
In your opinion what would be the max boost to run? I was thinking 20psi from other posts I read.
turrrbo6
Re: how much boost with 9.5:1 compression?
I run 24 to 26 on pump gas with alky. Don't let it knock and turn it up.:tup:
Windedv6
Ty n 10s
You should do a cylinder compression check. Your cam and cam timing will also play a part in overall cylinder compression. If you are 140# and under you can get away with 18-20 lbs on good pump gas, 20-25 lbs on alky and/or 110-116 octane.
If your cylinder compression is in the 150 lb range back the boost down from the above by 2- 3 lbs. If your in the 160lb cylinder compression range back it down another 2-3 lbs.
My 9.5 compression ratio had 180 lbs of cylinder compresion and I popped a couple of head gaskets at 20 lbs of boost on high octane fuel. I lowered the the cylinder compression down to 160 lbs by retarding the cam and a going to a slightly thicker head gasket. I am currently running 22 lbs boost with e-85 and everything looks good. I can probably go a little higher. I am running my timing at 24* at WOT with bowtie aluminum heads (56cc chambers).
As always, work your way up to your max boost levels and being a little fat on the WOT fuel is good insurance.
John
Syclone#2960
John
Thanks John this is exactly the info I needed to hear.:D
UR50SLO
V6+2=LSXCamaro
I agree with John... There are a lot of variables to what boost level you can run with a given compression. Camshaft does play a role..
Major things are...
Fuel quality... pump gas/race/e85.
Ignition timing
AirFuel ratio at WOT
Intake air temps
Backpressure in your system/turbo/exhaust size ect.
Your over all factor in how much boost you can run is detonation. You can run more boost and back the timing down or add race fuel or meth to suppress knock.
But overall.. like John said.. start out with lower timing and boost and bring them up slowly till you hit knock and back off for variables like hotter IAT's on a given day or poor fuel quality on a tank of gas.
Boost isn't what kills engines.. it's Knock!
~Scott
Windedv6
Ty n 10s
Depending on your cam, you can advance/retard it to make some changes in your cylinder compression. I originally set my TT motor cam up at 6 degrees advanced to help spool the turbos. This put my cylinder compression to 180#. It spooled the turbos great, but was to high to fine a sweet spot for tuning with more than 16-18 lbs of boost. I ended up bringing the cam back to 0* degrees which lowered the cylinder compression to160#. I still have good spool up and capable to run 20-22 lbs boost on pump e-85.
Not every cam will react the same way, with regards to changing cylinder compression, to advance/retard timing changes . My cam has .5 degrees overlap which is basically no overlap.
John
Syclone#2960
John
Looks like Im at 120psi...should be safe to 25psi on the boost.
