Do you read things people write - or are you unable to retain information.
http://www.syty.net/phpBB2/viewtopic.php?t=21755
A few responses into it says why you shouldn't use straight anti-freeze.
As far as the capacity of an IC system - lets think about it......
Stock system. Metal lines. Probably holds less then a system that has had the lines re-routed with 3/4" rubber hoses. Figure there are 50 different ways to route the lines - this is going to give you about 50 different numbers. Add an aftermarket IC - changes it even more. Did you pull the lower CCHE out and completely drain it - or did you just drain enough to pull the upper off?
I say start with 50 gallons - if it starts to overflow - stop. Let the IC run for a couple minutes - fill as needed. Drive for awhile - fill. Check it the next morning - fill. Check to make sure it isn't all dumping into the overflow - fill again.
Yes - I did say 50 gallons.
